12. Jun 2024, 00:33
Hello and welcome in our Board.
Of course this little Feather is very important. With a little Valve cap it is a Bypass Valve when your Oilfilter is blocked.
I also had searched in many shops,but no one can deliver it.
If you still have this little Valve Cap,measure the inside,perhaps you can use the feather(spring) of a ballpoint pen,or you can buy a assortment box in the Bycicle Shop "Louis".
I dont know the Length of this Feather,but tomorrow when I find the Time,I will remove my Feather for measuring the Length.
I really think that it is not a good Idea to close or block this important Valve,I think that it is also important for your Oil Pressure.
Perhaps you can use a Feather from a Honda 125 Bike,because many Parts are identic to Daelim.
One Question,,,,in your Profile you write that you have a Daelim VS,and in your Thread you wrote that it is a Daelim VT.I have seen that you can buy this Oilfilter Cover complet in our German Shop @Dataparts.com for a Lot of Money,,,that cannot be true.
I hope that my English is good enough and you can understand what I mean.
Greetings,Volker
(für URL bitte einloggen)-- Automatische Zusammenführung - 12. Jun 2024, 01:49 --
Perhaps you can find this little Feather in your old Oil.If you had opened the Screw with Oil in your Machine,this Valve Cap with Feather will flow with the old Oil in your Pot.If you change Oil with Filter,it is not necessary to open this Srew,ONLY THE COVER WITH 3 SCREWS AROUND.It is also important,when you rebuild the Filter,to look at the right Direction.At first the big Feather and after the Filter with the open side to the Cover!
-- Automatische Zusammenführung - 12. Jun 2024, 02:06 --
The Partnumber of this Feather is:
DAE-15416-BA6-9600
